Guys I have a question that maybe someone can help me on. The guy that purchased my 95 Raider 1100 let his friend use it and something happened.
He told me that a hose popped off and water pumped into the engine compartment and the ski died and wouldn't start. I assumed that the engine cooling/exhaust (pisser) hose came off but after looking at it yesterday it was the pulse hose that had come off. He told me that water was coming out of that and it almost filled the compartment. This made no sense to me -- isn't the pulse line just pressure to the fuel pump from the crankcase?
After trying to get it running yesterday, it seemed to be running on only the rear cylinder. There was spark on all the plugs. I was thinking that maybe the reeds got wet and have stuck close on the front two cylinders? There is back pressure blowing through the front 2 carbs but they don't seem to be getting fuel, hense my thought about the reeds being stuck. If water filled through the case pulse fitting could the lower have water in it? Also I think the ski was turned over the wrong way to empty the water from the hull.
Also after originally hearing this I told him to pull the plugs and get any water out of the cylinders, also put a little oil in them just to be safe. Maybe they put in way to much. Not sure.
Thanks,
Andy
Thanks,
Andy
