HI Bryan, where do i exit the bilge pump fitting on my 701 Raider hull,i need a place where i can turn it on so i can see when the water stops coming out.It does not get much water in the hull,it is a means of insurance.
Where do you exit bilge fitting on a Raider?
What ive done is taken off the syphon plastic square thingie (I know real technical) and then used the hose as the hose for the bilge pump. The syphon has a plastic 90* piece on it. DONT REMOVE IT because it contains a one way flapper. youll see a hole on the side of it jsut put a small screw thogh it so when you turn on the bilge water doesnt squirt out of it.. also what I did at that point was to take off the hose where it comes out of the hull and attaches to the pump and added a extra lenght of hose and then tan it to stick through the back of one of the holes that has the plastic black round things. ( tie down holes? I only use one so I use the other one so i could see the water coming out.
it keeps it clean and you dont have to drill your hull
Rob
