95 wave venture 700 carb settings
  • 95 wave venture 700 carb settings
    i am working on a 95 wave venture 700 twin carb. could someone please list the correct mixture screw settings the size of the seat for needle and seat and correct pop-off pressure. thanks. i am a certified sea-doo mechanic for anyone else out there looking for help, as well as kawasaki
    Re: 95 wave venture 700 carb settings
    700 - Low Speed – 5/8 +/- ¼
    High Speed – 5/8(M), 1-1/8(P) +/- ¼
    Not sure on the needle and seat and pop off
      i still would like to know the pop-off pressure range.
        If you don't mind me asking, what is pop-off? What is being popped off water or is it something for the fuel?
          Read the tech article on it.
            pop off is the amount of psi it takes to make the needle and seat unseat itself and aloow fuel into the system to run the motor read the tech article here at SBT FAQ section.
              so what do i do to look at the FAQs, or was that not intended for me. could someone point me in the right direction
                the FAQ are on the main idex pag when you come to the forums it has the screw setting but not PO it was intended to answer the guys question about what was Pop Off. It is where I got the screw settings but like I said it does nto have PO go to www.mikuni.com and it will list the pop off with the springs for you.
