I have a 94 WaveRunner 3 (WRA700) with a stock single carb. I have a couple of questions about the fuel system.
I'm wondering what type/model the carb is on this model?
Would you recommend replacing the choke with a primer kit (the choke is working fine)?
I've read the FAQs on initial carb settings but don't understand why there are three settings when the carb only has two mixture adjustment screws (not counting the idle speed screw)? The FAQ says:
700 - Low Speed – 5/8 +/- ¼
High Speed – 5/8(M), 1-1/8(P) +/- ¼
I don't understand the two High Speed settings? Which do I use?
Thanks for any help and advice you can provide.
Barry
Barry
