Just recently purchased a 89 Yamaha Waverunner and noticed that it doesn't have as much power as it should. I've replaced all the fuel filters, cleaned out the gas tank and replaced the spark plugs (B7HS). Also did a compression test and came out with approx. 145ib per cylinder. Mixed a 50:1 fuel/oil ratio and took it back out to the lake. It's still exactly the same. Takes forever to plan off and even then has a hard time of reaching 24+mph. When I got back to the house and checked the spark plugs they were dark brown in color. At this point I was thinking about rebuilding the carb and checking the impeller. According to SBT this year made two different carbs. The Mikuni BN and SBN. How can I tell which one I have. Any other opinions and/or tech support would be greatly appreciated.
Yamaha WR500F power loss
