how does rec compression affect time between rebuilds pls?
  • how does rec compression affect time between rebuilds pls?
    Brian
    If i put in a stock decked head bumping comp to 145psi range, will i still get 400hrs on my engine before rebuild in your opinion? How much degradation..200, 100, 50hrs between rebuilds?
    Your opinion pls.
    97 venture11/1200, 01gp12r stage1, 02F12X
    dav_dman@yahoo.com
    Thee is no magic number, but any mods you do will somewhat effect longevity. Compression alone will not greatly effect it, however your use and Maint. will.
    I would say that if conditions were perfect - you always had enough octane in the gas, for example - you wold see a very small like decrease. I think the greater risk is exposure to sub-standard gas, and your chances of detonation going up. You may run into a very hot day on the lake, some really crappy marina gas, and a long WOT run...that might introduce you to an early rebuild.
    Personally unless you can keep a REAL good eye on what you are doing, I'd go slightly lower - may be 140-145 and run 91+ all the time. It will give you a nice bottom end boost but you will have better peice of mind.
      thank you. I will know where i'm at in a couple weeks when i put this head on.
      dav_dman@yahoo.com
