Speedo doesn't mean a thing. What is your top RPM?
Then it's very hard to determine if you have an engine or pump roblem - unless someone experienced can ride it. It's very possible the engine is making the proper speed, but you have pump damage limiting your speed. Read the tech article on inspecting the pump for damage, and at least go over it. Without an accurate tach reading, no one can tell you exactly what's wrong.
