I was given a 1989 wr500 and have made numerous repairs over the last 3 years, including replacing the leaking hull. It sat in a covered boat dock for several years prior to my obtaining it. I pulled the engine replaced several head bolts, rear exhaust guide, and rear bearing. The cylinder walls and piston heads were in great condition (no scoring, burn marks, etc.) and had good compression. I also replaced all of the filters, cleaned the fuel tank and cleaned up the carburator (not rebuild) along with a new battery. It ran the first try, but I have had problems with it starting up after several good runs.
I replaced the CDI control, installed a new battery and it started right up. Now it is back to it's old games of being hard to start. My guess is that the Carburator needs a rebuild kit. Am I on the right track? Do I need to do anything else while I am in there?
A local jet ski shop had me check the CDI with an Ohm meter. Everything in the stator checked out good except the charging coil, which they said was not essentual to the running of the motor, just turning the motor over. They also said pulling the motor just for the charging coil was just not worth it. I also replaced the spark plug caps. Again, am I on the right track?
