I've collected (cheaply) some 1990-1993 waverunners for the kids (Of course not me) to have fun on and of course, have had the usual gamut of problems. I'm always dealing with dirty carbs, water in fuel, trash, filters, etc. I've become a pretty good waverunner mechanic! One seems to have alot of problems with fuel. Seems to take off fine then run out of gas...can keep running at very low speeds only...it will run great at any throttle setting but too much throttle and it is just as if it runs out of fuel. I'm just wondering if there is a possiblity that there is too much pressure on the needle valve causing this problem. Is there such as thing as pop-off pressure for these engines? if so, what is it? I've about pulled my remaining hair out trying to keep these kids in the water.
I've done about all there is to do except check crankcase pressure....I'm thinking about making block off plates to do that with (how much pressure/vaccum should I put on the crankcase when checking it?)
