My 1100 raider is having a little problem. In front of the motor is a rubber boot that says fuse on it. Once in a while, the wires inside of this come loose, causing the ski to not start after I turn it off. All I do right now is put the wires back together and it is fine. Has anyone else had this problem and what did you do to fix it. I don't want to just put them together with electrical tape because I don't know if there is supposed to be some fuse in there. Any suggestions would be really appreciated.
