I have a 95 waveraider 1100, I have added
boyeson pro power reeds
removed choke plate and assembly and installed primer
installed three ocean pro flame arrestors
installed 95 gram pop-off spring with stock n/s which my yamaha service manual says is 1.5 stock
I have maintained the stock jetting 75 lows and #1)107.5, #2)95, #3)107.5
I first was not getting any top end, I cured this by turning out my high speed screw one half a turn untill it didnt drop off at WOT. It is not at 2 turns out. now running 67 on the speedo, which is around what it was before, seems to be working fine. but!!
I am getting a bad hesitation or even dying after a highs speed deceleration (running top speed letting off, then accellerating quickly again) If I let the decelerate and then let the ski sit for a scond or two and then hit it again it runs fine.
At stock carb settings this problem started anywhere between 15 mph to 45 mph on the speedo, as I turned out the low screw in quarter turn increments this gap got smaller 1/4 turn more out dying and hesitation only 15-35, another 1/4 turn out 15-25, and so on.
I am now at 2 1/2 turn out on my lows and 2 turns out on my highs and I still have a little bit of hesitation in between 12-23 mph
I feel I need to rejet, maybe 85 on the lows and 115 on the highs? any suggestions.
Thanks,
Thanks,
