Hi All,
I am a proud new owner of a used 1997 Yamaha 220 Twin Jet. I have been reading your forums and am impressed.
As I said, I recently bought a Yamaha Exciter 220 and while it ran OK, I have been trying to sort out some issues. First, the background: low hours on engines, 115 - 120psi on all cyclinders, clean, sitting for two years, winterized, all original except single battery instead of dual, oil system works on all cyclinders. Regassed, fired up and ran through a tank of gas. Boat runs great at top end. Inside engine stalls in high speed turns. Both engines bog if under full accelleration from full stop (skier pull out), especially starboard engine. Rebuilt carbs on starboard eng. Engine purrs, dramatically reduced number of stalls in high speed right turns (port eng still stalls in high speed left turns, will rebuild port carbs tonight).
Can anyone comment on the need for a fuel/air separtor? The stock fuel filters (clear plastic) are largly full of air. Tried to bleed but design of filter prevents removal of air. Researched and found a large amount of information regarding hesitation under full accel especially when turning, rough water, or less than 1/2 tank of gas. A fuel/air separtor maybe even with an electric fuel pump makes sense to me. Anyone with some experience?
Thanks in advance!
Thanks in advance!
