new sbt engine runs great, but when I give full throttle it boggs down and sometimes shuts off and ideas?
bogging down
Re: bogging down
this ski has primer instead. but you think I need to rebuild it ? and if so is that hard to do?Last edited by aviatorflyinhigh; 09-03-2005, 04:34 PM.
Re: bogging down
im getting there i trimmed the spark wires and its running alot better. there is a kink in one of the exhaust hoses and i think that could be the problem as well. The fuel filter is new. the engine is vibrating alittle too much could this be a factor of improper alignment of the drive shaft?
Re: bogging down
If you can define from the engine sound that its an electrical problem, it may still be your spark wires. What year is the ski? I have a 93 that I've had to replace the ignition coil/spark wires on because it was breaking up after 5000 or 4500 or so
Re: bogging down
You already got the correct advice - Did you actually use new carb kits? Did you test pop-off? Have you tried tuning the carbs?SBT Tech Support is here to help with your problems.
Re: bogging down
Read the tech articles on pop-off and carb tuning. If you have an electrical mis-fire, yes you may need new wires/coil - I can't tell over the internet.SBT Tech Support is here to help with your problems.
