I'm trying to put my GP1200 back together after replacing the motor mounts and I could really use some help at this point. I'm totally stuck unless someone with experience can help at this point cause I don't have the experience to know how this should sound or feel out of the water.
The first hurtle was when I tried to start it. No starter at all at first. That was easy because electrical is my "thing." Apparently one of the connectors was not seated right.
So, then the mechanic who's working with me (all automotive experience, no 2-stroke experience), and I started it about 3-4 times. It climbs up to high RPM with the throttle plates almost fully closed and sounds knocky and horrible to us. I choked it to bring the RPM's down to run it for a second. One of the times it was at about 2-3k for a second and sounded like the engine was running smoothly and as it should, but mostly sounds bad and won't idle at 1500 RPM or so. We were pretty careful (at least we thought!) to not mess with any of the adjustable things and to put it back together as close to the way it came apart (adjustment wise) as possible.
If you look down into the carbs, you can see that the front carb's throttle plate is fully closed when you're not on the throttle lever on the handlebars, but the middle one is open a hair more than the front plate, and the back throttle plate on the rear cylinder is open a hair more than the middle one. The back throttle plate is open maybe 3/16 of an inch? My friend has a lot of experience with carbs like these and can't find a way to adjust them. Is this a normal way for the plates to be, and has anyone seen something like this before?
Also, would it be advisable to add oil directly to the gas until I can ensure that the oil injection pump is bled right and working, or make up my silly mind whether to go premix? With the engine not running I made sure the oil hose oil was flowing before I put it on the bottom of the oil pump and I opened the bleeder screw. We saw oil flow out of all three holes in the air cleaner when the engine ran, but i'm scared to death that the oil injection will not be right and blow a cylinder or the whole engine!
Lee B.
Lee B.
