Theres no point in doing that unless you want to spin out alot and not be able to turn efficiently at all. And it also leaves holes in your hull unless you seal them up (which isnt an option if you just wanted to try it out, which is understandable).
Its basically like taking the skid off a flat bottom boat (the long fin for tracking) It'll slide in the corners alot and you have a higher chance of crashing it if something comes at you at last second.
