carb rebiuld question??
  • carb rebiuld question??
    i was just rebiulding the carbs on my gp1200 and i have a question. what is the trick to instaling the new plastic check valves without destroying them?
    thanks
    chris.
    use a drop of oil on the grommet, and slow ly work it around in a circle. Once you get the end through a bit, use a screwdriver to lift it through.
      I replied HERE
      ***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
