The engine has 110 hp, is quite reliable, and is very thirsty.
The hull is a 3 seater, and i think it tops out at around 55mph.
There is also an identical wave venture except with a 2 cylinder.
The engine has 80 hp, is very reliable, and is much less thirsty.
Same 3 seater hull and I think it tops out about 45mph.
The hull is as big as a couch and almost impossible to tip over. I've jumped ocean surf waves with it though, so the couch is no slouch. Great family type ski that will still do all the other stuff too.
If you want the fastest ski, this is not it
If you want the best jumper, this is not it
If you want the most nimble ski, this is not it
If you want a good all around ski, this could be it.
Just because you are paranoid, it doesn't mean people aren't talking about you
