Is there anyone that make a kit for the I- Body carbs. I have a XL1200LTD, with the PV motor. [img]graemlins/cwm3.gif[/img]
Throttle Valve & Shaft Rebuild Kit
What do you think of the Buckshot Carbs. I know where I can pick-up a set for $500. Would they be good for a rec. ski (pulling tube & skier) plus the go fast times also. Don't know much about them. I was told for my sticking carbs to rebuild the shafts. I have a stinger3 and F/A from Riva and your motor. What do you think.
you should be able to buy the throttle shaft bushings from riva or www.pro-tecperformance.com. Protec has a mikuni parts explosion for the sbn that you can reference when talking to them on the phone..be sure to say yours are I-body however...might be a difference in bushings.97 venture11/1200, 01gp12r stage1, 02F12X
dav_dman@yahoo.com
