I installed a Yamaha GP1200R motor last December and now have top end power lost & engine mis after 41 hours. Cylinder #1, compression is 116#, Cylinder #2 & #3 compression is 110#. The first cylinder is running lean, 2 & 3 are burning rich and the engine has a steady mis. When the engine was running great it would max at 63mpg and now I'm lucky to get it up to 50mpg. I've check the carbs, powervalves linkage everything seems to check out fine. I'm not sure were to look next! Any suggestions would be great!
Thanks,
Thanks,
