Morning , Put my ski I purchased in the water yesterday a 1995 wave raider with twin carbs and an 80 Hp engine. The ski started up well ran well but the idle seemed to be high when I let off the throttle the ski kept moving anway. Is there a way to adjust this on the engine. such as an idle set screw. Thanks in advance docUP
Adjusting Idle
Yes, if you follow the throttle cable to the carbs, you will find a t-bar set screw where the cable attatches to the front carb. Idle is 1500 RPM, 1-2 MPH in the water.SBT Tech Support is here to help with your problems.
