Does anybody know if I can use NGK caps instead of the factory ones ,If so what part # would I need for a 1996 Waveraider 1100
Spark Plug Caps
Service manual (Genuine Yamaha) calls for 4-6000 ohm in the cap... Look for the same in the NGK line, be considerably cheaper than genuine Yamaha part.
Probaly go straight to plug, no resistor, do not have radio noise to worry about.***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
Hotter spark will come from higher voltage coil, and wider gap.Originally posted by caphowie:
I think the resistor is supposed to make the spark hotter
Resistor is resistance to flow, thats why the carbon impregnated wires on your car will not allow plug to fire if resistance gets to high.... coils on watercraft typically have solid wire core plug wires, then a cap with a resistance built in to reduce electrical interference.***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
