Just dropped this baby in the lake and it seemed to run great at first. After a short run at about 4000 it started to sputter and loose power. I barely got it back into to dock and changed the plugs/probably fouled due to the engine fog from . After a brief run with the second set of plugs in started to sputter again, checked the plugs and they were a bit oiled up. Ran about a tank full of gas with intermittent periods of the unit running good then bad then good. I put a 4th brand new set of plugs in the unit and was immediately disappointed that it ran poor with no zip once again. This unit ran pretty good until it was winterized and only has 17 hours on it. It is also still under warranty. Perhaps I should of purchased the 4cycle? PLease help:emoticonb
2005 xlt1200 Plugs Fouling
This topic is closed.
Re: 2005 xlt1200 Plugs Fouling
