IS IT COMMON FOR THE 1100'S TO SMOKE AT IDLE? NO MODS. AFTER IDLING FOR 1-2 MIN LOTS OF WHITE SMOKE. Local shop said there is no adjustment for this.
YAMAHA 1100
Normal, even with pre-mix... That big ole water box is a dead air zone, so it just collects the smoke at idle (no velocity at idle), till you yank the throttle to purge the exhaust system. I take and "blip" the throttle every little bit to keep the exhaust system clear.***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
