I'm in the 3rd stage of break-in (up to 90% throttle). I was able to, at 90%, plane the ski and had more power than original (bad) engine had when it did run.
But then, ski began to shake and vibrate a lot and great loss of propulsion occurred and sounded like I lost main bearing or something. To be clear, my RPMs were not affected (yet - see below), but rather it was a loss of propulsion; it was as if I lost my impellar (prop?), driveshaft, etc.
Then, I had propulsion back but only able to accelerate to 50% throttle - no more. Any past 50% and ski died as if it were being given too much fuel.
This is reminiscent of original engine, which had only one good cyclinder. Or perhaps my temp sensor is either malfunctioning and only allowing one cyclinder to fire, or it is working properly and I was overheating and it was only allowing one cyclinder to fire.
I will check compression in both cyclinders tomorrow; but until then, any thoughts?
