1994 Waverunner III Carb Settings
  • 1994 Waverunner III Carb Settings
    Could someone please post the H and L mixture screw settings for this machine with the stock 135 main H jet and the 115 L jet. This machine is totally stock.
    At the base of the carb there is a number scribe on it like 6j12 or something to that efffect find it and post it. this way I can give you the correct settings.
      I can't find a number similar to that on this carb. If someone has a Yamaha manual for this machine the carb settings should be in it ??? Thanks
        OK if you have a 61X 701 engine than here are the settings
        Low 1 7/8 + or - 1/4 turn
        High 1 5/8 +or - 1/4 turn
        If you have a 6M6 650 eng than here are the settings for each carb by number.
        ID number 61L00 low 1 1/16 + or - 1/4 turn
        High 1 1/4 + or - 1/4 turn
        ID number 61L01 Low 1 1/4 + or - 1/4 turn
        High 1 5/8 + or - 1/4 turn
        ID number 61L02 low 1 + or - 1/4 turn
        Hope this helps you out. [img]tongue.gif[/img]
          Great!!! Many thanks for the info, I sure appreciate it.
