can pick up a 96 waveradier cheep, it has a blown 1100 motor. i also have a 701 61x motor,will it fit in place of the 1100,. what problems will i encounter.
96 waveradier
It would require major work because you need the electrical system, intake, exhaust, carbs and flywheel. If you have this you can do it but it would be better to replace the 1100 due to the cost of the parts you need.SBT Tech Support is here to help with your problems.
