Here's a crazy one. Putting engine back together, locating pin from cylinder 1 falls into threaded hole for cylinder mounting, which I did not know until I tightened it and it broke out the bottom of the screw hole. The hole is the right hole on the exhaust port side. Maybe it is wishful thinking but I cannot see any way this would leak. Any thoughts?
Broken Screw Hole In Crank Case
Re: Broken Screw Hole In Crank Case
As long as the threads are good and the bolt is to torque, and the inner wall did not crack, it should be ok.SBT Tech Support is here to help with your problems.
