any thoughts on the gp800's? rather good bad or indifferent. im divided between a 97gp1200 and a 99gp800 with a new engine. speed isnt an issue. reliability ismore important.
99 gp800 good bad???
The powervalve Yamaha motors are not nearly as reliable as the non-pv motors - the valves themselves have design issues and require aftermarket parts to be reliable. The 800 is not as bad as the 1200pv, but it's still not nearly as good as the older 1200 if you are looking at GP hulls.SBT Tech Support is here to help with your problems.
thanks tech, i see where your coming from. the older 1200's i heard are great engines and thats what im looking for...reliability. i wasnt sure about the 800's and thats why i had to ask. the 1200 is closer to whare i live by a couple hundred miles so that makes the decision easier too. thanks again
if you are conbcerned with reliability you should get the 97gp1200. The 800 has power valve's and requires more maintenance. The 1200 engine is a high performance engineSBT Tech Support is here to help with your problems.
