Well.....xX510 it's like cars....some swear by Fords..and some like Chevys..../shrug .... Now SBT does offer their warranty for 1 year if you ready their statement on the web site...it's a fault free waranty...basically no matter what they would exchange or rebuild your engine. All of SBT engines are bored 1mm over....so there is some truth to them being at the point of when they need rebuit you would have to Resleeve the cylinders on them to install new pistons etc. If you are new to jet skis let me tell ya really quick...when you goto rebuild yours...Like I did mine....if you just happend to need to replace the crank.....BAM...there is 800 bucks....right off the top..then you have gaskets...seals...etc... It's not cost effective really to rebuild yours unless you know for a fact that all the bearings, lower crank seals, etc are in great shape. IF you have an air leak some where in the lower cases....and you run lean....and well you start all over again. I have installed actually a couple of their engines..and they were TOP notch....and have been running strong..with not a single issue. NOw as far as bead blast....duunno about that but when you produce that sorta turn around on engines....your always going to have a few that are not quite right. That's why you have a warranty :D The engines last usually around 100 hours before you want to freshen up the top end...and the lowers....should last around 400 hours...depending on how you treat it...
Hope this helps!
Cheers,
Mike
[ January 28, 2004, 08:31 AM: Message edited by: Mpeavler1 ]
Hope this helps!
Cheers,
Mike
