cooling system diagram
  • cooling system diagram
    hey i have a 96 waveraider 1100 triple and i just rebuilt the motor and i put it back in today and took it down to the water, but when i took it out i ran it for about 5 minutes and lifted the cover to see the motor and it was leaking water from the exhaust, just wanted to know if i had the hoses on right so i now the motor is getting water.
    Re: cooling system diagram
    Do you the factory Yamaha service manual ?
    Where is the water coming from exactly ? Got pic(s) and edited in "paint" to show where the leak you is seeing.
    Another thought is go to HLSM.com, or the Riva site, and use the parts finder section, and study the pics there to jog your mind as to whether there might be a clamp you forgot or improper hose routing.... Hopefully you did not take apart the large rubber boot at top of manifold, as there is another section fo tubing inside there with 2 clamps to seperate the exhaust flow from the water jacket.
    ***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
      thanx but i finally got it running good and its not leaking any water thanx for tha help
