I have a 1998 1200XL, What is my correct premix ratio? I have removed my oil pump and installed the block-off plate. But I keep hearing different ratios to use.
32:1 is correct for the powervalve motors, that is the heaviest the pumps went to at WOT. 50:1 is for all other Yamahas.
OK guys, i have read 40:1 and 50:1 as the ratio's for premix on Yamaha. I have a 760XL and am almost finished with first tank of gas for break-in on "new" SBT engine, what is the correct ratio for next tank, using Yamalube? Thx
