The two fuel pump check valves on a Mikuni SBN come with a blue mark on them. Does this mark face the metal it seals against or away from it?
Mikuni SBN Check Valve
Re: Mikuni SBN Check Valve
I seem to recall that the instructions in the genuine MIKUNI kits state the blue dot is to indicate which direction the valve supposed to be installed.***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
After I read your message, I went to the garbage and pulled out the paper that came with the kit. You are correct. Evidently, one side is cupped. I am having a horrible time with my carbs causing a lean condition that cannot be corrected. If these are wrong, is is enough to cause a major fuel supply problem? Also, do I have to buy 2 complete kits to get the check valves?
Yes Mikuni's are cupped, ours are flat and it doesn't matter.
I was assuming because you are posting on our site you meant our kits, my apologies.SBT Tech Support is here to help with your problems.
