i have an 01 gp1200r looking for a little more power, i have the scoop grate and pump seal kit and will be adding a 13/19 prop soon. will adding an aftermarket head take away from the reliability and its life of the engine?
aftermarket head
No. If a quality head is installed and proper fuel used, it will not significantly effect overall life. It's care and use that determines a ski's life.SBT Tech Support is here to help with your problems.
If ANYTHING is done to the motor on the 66v, I usually recommend rejetting the carbs. Ive seen too many times when these carbs arent jetted correctly and leads to engine seizure, especially if anything is done to the airbox. The carbs on the 66v are notorious for this. If your going to go through the trouble of pulling the carb rack, drilling out the tamper caps which block the high and low speed adjusters, i would set up the carbs the right way the first time around.
Island Racing,
ON a stock 98 GP 760 does there need to be any pop off adjustment or jetting changes for just installing K&N F/A ? The only mod it the choke plates removed and installed primer kit and now want to put the K&Ns. Is it safe to say we could just turn the needles out some for this?
Thanks,
Mike
On a 760, head only changes, you will need to open your high screws about a 1/4 turn to start from for safety, the rear cylinder in particualr.SBT Tech Support is here to help with your problems.
