I need help verifing what this part is and what it is for. I have one brass nipple coming out the top of the crankcase/cylinder head. What is this for and what type of engine is this on. I looked at other engines but could not identify it.
Help identifying yamaha 1200 non pv part.
Re: Help identifying yamaha 1200 non pv part.
How about a better description, or maybe a pic or 2 ?***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
Is the nipple coming straight out the back of the head? If it is that is for a cooling line
Thats on a '98 GP1200 non PV.
you can go to www.rivamotorsports.com
and click on OEM PARTS link and enter your machine (year & model )
The nipple is coming staight up from the top of cylinder #2 at the top of the cylinder case. I was told by a friend that it may be a water bypass kit. If so How is it used and what connections do I use to complete this?
Post on www.pwctoday.com for more aftermarket support.SBT Tech Support is here to help with your problems.
