i'm going pre mix on my waveblaster II. i blocked the lines at the intake, when taking off the oil pump i just install block off plate, right.just like a sea doo.
pre mix yamaha
Re: pre mix yamaha
If you go that way is it necessary to remove choke plates or can you just leave as is and disconnect the choke cable as this would avoid having to pull the carbs (yamaha 1100) and mess with the removal of the choke plates. I would put the primer where the choke is now. Thanks
