Hey all. I recently got a couple of 4 stroke yamaha vx110 waverunners I took them out today or should I say I tried to take them out. They start up fine but not long after the warning system starts to beep and the little engine pops up on the instrument panel.you are unable to accelerate atthis point wich I am sure that is a safety feature. I have checked the oil and the fuel. They seem fine. I do not understand what is causing the problem. I also want to know if when using the flush kit should water flow from water cooling jet. Any thing helps. background on the bikes as best that I know is that the bikes have not been used in about a year but have been started every couple of months. I hope this helps. Thanks to all that reply.
vx 110 warning system Please Help
Re: vx 110 warning system Please Help
Could be an over heat warning, low battery voltage warning or a faulty sensor. You should take to a dealer and have them run diagnostics on the machines. Its worth the money these are big bucks to fix if you over look some thing.SBT Tech Support is here to help with your problems.
