I have 2 2001 1200XLTs and for some reason they are not getting any fuel. Both had sat with no fuel in the lines. However, when I prime the cylinders they fire right up until the fule is completely burned out and then dies. I hooked up an electronic fuel pump on the line and it fired right up. Is there any way to fill the fuel lines up without using such pump?
NO GAS 1200xlt fel problem
Re: NO GAS 1200xlt fel problem
Sounds like the fuel pump seals dried out, Might need rebuilding also open up the carbs and make sure the needle and seats are not stuck. Dont run a two stroke out of fuel for storage, just add gas stabilizer and start the ski up for a few seconds every once in a while to keep the fuel moving around in the carbs.SBT Tech Support is here to help with your problems.
The fuel pumps are part of the carb, its mounted to the back side of the carbs, with fuel lines going into them, and pulse line from the crank case going to them.SBT Tech Support is here to help with your problems.
