capsized vx110
  • capsized vx110
    let my friend use my ski i rolled it in the water and had it towed in i pulled it out of the water and opened the drain plugs and tryed to start it . it would turn over but will not fire i checked the oil to see if the oil tank had water in it but it looked fine so i took the plugs out to see if there was water in the cyliders but there was verry little moister on the plugs. so i changed the plugs and it fired rite up . upon further inspecton of the air filter and air box i found a good amount of oil inside i guese oil flowed into the air box when it was upsidedown . my question is i washed my filter with fuel think thats ok?manuel says dont clean it i dont see whats the big deal plus there like 80 bucks new.also think i should cange the oil i ran it hard for 10 minutes oil dont seem milky i was realy suprized to not see any water in the cylenders or in the oil just little moister:)
    Re: capsized vx110
    You dont clean those filters, Get a new one, 80 bucks is cheap compared to the price of a new motor. Tom SBT tech.
