97 waveventure 760 no start no display or spark, does crank ok, tested most componates by the book, What turns on the display on????? Pulse Coil???? or what? changed out CDI with used one hope 2nd one isnt bad. Cut out swithes are OK tested. Went to start after winter thats when this happened.........
760 Waveventure No Start 1997
Re: 760 Waveventure No Start 1997
This sounds like a bad or corroded connection somewhere. You may have done this, but check and clean all plugs and connections/grounds.
I have found that it is best to at least bump the starter on any winterized motor vehichle once a month or so to prevent corroded connections.
Originally posted by Merrrdoc97 waveventure 760 no start no display or spark, does crank ok, tested most componates by the book, What turns on the display on????? Pulse Coil???? or what? changed out CDI with used one hope 2nd one isnt bad. Cut out swithes are OK tested. Went to start after winter thats when this happened.........
