installing block off kits
  • installing block off kits
    what ratio do I premix?, do I just put the oil in the gas tank?, will it mix on its own? will it separate?
    Re: installing block off kits
    This is an LS 2000 boat
      you should use the search button bud. This question has been answered a few times before.
      32:1
      1997 Speedster (twin 720s)
      London, Ontario, Canada
        OK, just read searches for 3 hours, looks like removing the tank on a Yamaha is ok, their seems to be no other oil line to lubercate anything else, the directions only pretain to Sea-doo.
        Mix the fuel at 50:1
        Still don't know if its OK to mix in the tank, will it mix from the gas pump
        to the ramp? and once its mixed does it stay mixed?
          Sorry, I mis read your original post, 32:1 is for break-in.
          Yeah you mix in the tank. Yes, once it is mixed, it will stay mixed.
