I have a "spare" '93 GTX for parts.. can I use the "T" fitting for the flush kit on my '91 Waverunner. So I can use the same hose connection for both of my running ski's?? I'm not sure how the Yamaha flush kits fits.
flush kit
Re: flush kit
Yes you can. Yamaha has a similar thing, but you still need an adapter to make it work. I put a SD flush kit on my 550 years ago, for the same reason as you.Dan Solie -
Re: flush kit
you can put t wherever you want, as long as it feeds the motor and exhaust with water. I run all mine like the newer yamaha's. I "T" right into the main IN.Dan Solie -
Re: flush kit
Not sure on that ski.. You would just need to trace it back to the pump area.. The line coming FROM the pump is the INDan Solie -
Re: flush kit
the hose on the left side looks like it goes to a bilge pumlp in the engine area, the hose on the right goes into the block under the exhaust manifold. Is that the "IN" for the water into the motor? Can I use the hose the runs from the head down to the case? it's a short hose.
