2000 GP 760 no spark-charge coil?
  • 2000 GP 760 no spark-charge coil?
    any common problems w/ this ignition system? charge coil is out of spec, other than that there is no description of what the charge coil actually controls. anynone have any info?
    ASE Master Tech
    ASE Advanced Level Specialist
    GM Certified
    Cadillac Tech
    Been fixin and riden skis since 05
    Re: 2000 GP 760 no spark-charge coil?
    Charge coil produces A/C voltage to send to the regulator/rectifier to be converted to D/C voltage to keep the battery charged and run the electrical system for ignition.
      you would think that becuase it's called the charge coil it has to do with the charging sysstem, but in the factory schematics it has nothing to do with the charging system but somehow is involved with the ignition system. I have no spark and this is the only think that doesn't check out. Already swapped ignition module w/another but didn't fix the problem
      ASE Master Tech
      GM Certified
      Cadillac Tech
        Did you check your start switch? The switch has two connecter a black one and a red one.
        The black connecter will have a blk and wht wire, this gives a ground to CDI and will kill excitation volt, (no spark).
          start and stop switches both working to spec
          ASE Master Tech
          GM Certified
          Cadillac Tech
