Hey everyone.
I have a 2001 800GPR that i bought couple months back from a guy that said it had a low compression on #2 cylinder. So me and my buddy rebuild the whole top end, both cylinders, both new pistons, rings, ext, new powervalve eaters. It also has a aftermarket prop "solas", with a bigger pitch. When we took it out on the water and hit the gas the ski would start to pickup rpms but would not go forward. So we intalled a plug kit from riva to prevent cavitaion. Back on the water again. When i hit the gas, the ski would start going slow, about 10 rpms for about a 1min and then slowly picks up speed, and than at about 20 or 22 rpms the engine kicks in and accelerate right away like it's about to throw you of the ski. Same thing would happen when i go jump the waves. The ski will not take off sharp until i jump a wave and the engine would kick into high rpms and will throw me off the ski. I reinstalled the original prop and still is doing the same thing. When we had the carbs off, I didn't rebuilt the carbs but took out the low rmp needles and cleaned them out and reinstalled the needles to factory setting, same amount out before we tooke them out, but left the high rpm needles intact. What should I do next? Should I rebuild the carbs from ground up with the rebuild kit from SBT? Please help... I want to ride my ski couple of more times before the end of summer. Thanx for any help.
Mike
Mike
