Have backed adj screws out full 3 turns trying to get it to run richer, pulled plugs still very white, compression on both cylinders 110psi. Takes awhile to get full speed at 43 mph, 800 should run faster (55-57) right? Rave valves open and close on trailer but not on lake test. I,ve disconnected rave valves at wiring harness, so valves are closed and have no problem accellerating on the lake. Ski has less than 35 hrs on it. Could this be wrong jets from factory. Any help is appreciated, THANKS.
03 gtx 800 runs lean
Re: 03 gtx 800 runs lean
Did you check the internal fuel filters in the carbs? They might be logging up, How old is the fuel in the tank?SBT Tech Support is here to help with your problems.
