I am looking at buying a 1200 SUV, 2002. The unit has 69 hours on it and is in near perfect condition. All maint. done...stored indoors etc... The unit is very clean.
The owner and I checked the compression and only got 85 psi on all cylinders. However, the unit seems to run fine. The fact that it is this low and the same in all locations, would seem to tell me we either did it wrong, of the guage we used is bad. I would think at 85 psi, it would run like hell...if at all.
Any thoughts?
We had all plugs out when we tested it and simply cranked the motor over.
How many hours should you be able to get on one of these before needing a re-build?
Any thoughts?
