98 YAM 1200 XL. I am about to remove the oil pump as outlined in your technical articles with a block off kit I bought from SBT. My question is:
Once I drain all the oil out of the oil tank, how do I diable the low oil warning light/aural. Also for pre-mix: you recommend 40:1. I will be using quality Yamalube 2W.
Another issue that causes concern is the oil injection system in general (when healthy). Too many zip ties and the
design lends itself to something coming undone. Do any companies make aftermarket oil lines that have the oil line
and check valve as one integral piece? This design would limit the number of zip ties to 2 per oil line instead of
4 per oil line.
4 per oil line.
