Hello Guys
I need a little advice.I bought this waverunner new and have lost about 7-8 mph over the years.Before last summer I pulled the top off the engine,replaced the rings,did a mild port and polish on the intake and exhaust side,removed the chokes and installed a primer kit.It did not help the mph at all.So we rode it all last summer and this summer up untill now.I have noticed for the last month it will not take off like it suppose to.When you hit it full throttle from a stand still or about 10 mph it revs wide open untill it gets to about 20 mph before it will grab and then its gone.It acks like a stick in the impeller.Today I removed the pump housing and impeller.impeller looks like new but the housing around it has a few scars and ridges in it.Is it possible this is causing the cavitation and the loss in MPH I am expercing.There is a good bit of alge and crust inside the pump and on the grate.Does the pump housing have to be replaced or can the wear ring be removed and replaced...Thanks for your help and looks like I have found a good place to hang out........AR
