First, these forums are great! Glad that I found them and I am hoping that I can get back on the water in short order.
I have a 2000 XL1200 Limited. Recently had it out on the lake and during a run at full speed, it bogged down and I could only get about 25 mph out of it. Took it out of the water, found some rocks in the intake grate, inspected the impeller which looked undamaged, checked to make sure no fishing line or anything else had wrapped itself around the driveshaft, all the plugs were firing, and still couldn't get it run right.
Took it into the shop and they called me and said I need a new engine. Huh? What? With only 50 some hours? They found out that there is 0 psi compression pressure on the #3 cylinder. Bummer for me.
I have since found this forum and now realize that this seems to be a fairly common problem. So, this past weekend I removed the Stinger and then the exhaust last night. Removed the cylinder head and here's a picture of my #3 cylinder.
#3 cylinder, piston head
Cylinder Head - the far left one was over the 3rd cylinder.
I think that this is Cylinder #2.
Obviously this is a minimum of a #3 cylinder/piston rebuild, but first I want to know what could have caused this? Looks like melting due to overheating - would this be from oil starvation? How long would this have been going on before catastrophic failure like this? 1 day, weeks, months?
I bought this used a few years ago and have probably only put on 10-14 hours since then, and probably only 2-3 this summer. This was only the second time I had it out on the water this summer and this happened about 40 minutes into the session.
So, I'd appreciate your wisdom and guidance.
1. What could have caused this type of damage?
2. What's my next step? Remove the engine, remove the cylinder and piston and check the crank for any metal remnants?
I rebuilt a motorcycle engine many years ago (when I was a teenager) - I am ok mechanically and think that I can do this. I definitely can do the whole engine replacement, but I'd certainly rather do something that costs less if it means having to tear into the engine a little bit, for example if I have to replace the crankshaft.
Thanks!
Thanks!
