I have an 03 LX 210 and my driver's side engine is slowly losing power. The boat runs great for the first coupler of hours out on the water and as the day goes on the driver's side engine begins losing RPMs. Besides seeing it in the tach I can eventually notice the loss of power in the speed. It will hit 7000 rpms the first time I do a full throttle run. Then it will begin dropping about 500 rpms with each full throttle run all the way down to about 4500 rpms. This is happenning gradually after using the boat most of the day. I have switched fuel lines, replaced fuel and oil filters, added ethanol treatment to gas, drained fuel tank, did a compression check, and changed the fuel tank vent. Any suggestions?
Thank You
Adam Zondor
Thank You
Adam Zondor
