Will not transition between locked and unlocked without disconnecting and then reconnecting the battery. When this problem first showed up, the Waverunner would still start as long as it was unlocked. Now, the start button does not start the Waverunner.
The brown wire to the starter relay gets +12V when you press the start button whether the waverunner is locked or unlocked.
The black wire to the starter relay does not get ground when you press the start button whether the Waverunner is locked or unlocked. This wire comes from the receiver for the security.
Starter and Starter Relay tested and work fine.
Engine cranked and ran fine before start button quit working.
If I manually activate the starter relay, the Waverunner runs fine, but the engine warning and oil lights are displayed.
